Diesel Forum - TheDieselStop.com - View Single Post - Leaking Glow Plug Control Swith???
Old 12-03-2009, 11:14 AM   #5 (permalink)
chuckster57
chuckster57's Avatar
Like Joe Mc said..You can run an aftermarket pressure gauge. There are the electric styles and the mechanical styles that use a thin tube. Your pressures will be about 10-12 PSI @ idle and 35-40 @ cruising when fully warmed up. So if you do go with an aftermarket, make sure it reads 0-60 not 0-100 as it may not register @ idle.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline   Reply With Quote
