Another "trick" is to actually hammer the go pedal. I have never had an issue with my limited slip so long as I really get the wheels spinning. A little bit of go pedal doesn't engage the limited slip, unless you do the foot on brake trick. i would also question what kind of tires you've got on your truck that you get stuck in wet grass.
2004 F350 Crew XLT 4x4 long box, SRW, 3.73 Gears
Bone Stock
