Have seen a combination welder/generator which was belt driven mounted on a contractors truck (PS). The contractor had mounted it so was aftermarket. Worked well for welding don't know about the generator part. No idea where it was purchased but they were electrical contractors installing generators and associated systems.
I use a 400W invertor with which i can run an impact wrench and have also ran a 14inch electric chain saw. Also have a 1200W invertor which is never used. I just snap the jumper cables on the inverters on the battery and let the engine idle for such period of use
Reason: add info
