Diesel Forum - TheDieselStop.com - View Single Post - Coolant Flush - VC9
Old 12-09-2009, 10:28 AM   #26 (permalink)
69cj
69cj's Avatar
Originally Posted by Jayco1c View Post
Guys please answer his question what about the VC-9 Iron cleaner.
And can you get it at NAPA.
Question: I didn't use the VC-9 iron cleaner. Do you guys think that I need to repeat the flushing process illustrated above but use the VC-9 to clean the internal coolant passages as well as the oil cooler?
The only place I found the VC-9 was at dealer. $26.50 per qt. 2 needed. As for repeating I cannot answer that since I have no idea the condition of your system. The only reason I went with the expense is the tech at the local dealer said that he always uses it and it is a Ford recommendation if not a requirement. Ford did say to use it in the letter that they sent me on nitrates.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline   Reply With Quote
