Diesel Forum - TheDieselStop.com - View Single Post - considering wmo!!
Old 12-13-2009, 04:08 AM   #10 (permalink)
skibarefoot
I mostly use atf at 50/50. My wmo is mostly atf but I'll dump in oil and hydraulic oil as i get it too. I then fitler the 50/50 mix. The truck is a 44 gallon tank. I ussually have about 22gals of diesel then I pump in the 50/50 filtered mix.
2002 EX 4x2 Amsoil front to back with Amsoil oil bypass filtration, Cyclone Power fan, HX oil line, Dieselsite prepump and tank mods, local high performance transmission, MagHytec pans,MBRP 4" exhaust, AFE Stage II, BD EBV exhaust brake, Bright Box, Diesel Turbo Life Saver, Dieselsite 6pos. chip, Trans, EGT, Pyro and water temp gauges, Dieselsite tranny cooler, Dieselsite 203dg t-stat, Dieselsite AIH plug, rerout ccv, Coolant filter, Firestone Ride Rites, hellwig rear sway bar, Garrett BB turbo. Dieselsite hpop filter, Auto Enginuity program. Dieselsite Adrenaline hpop.
skibarefoot is offline   Reply With Quote
