Originally Posted by gitsome05
he did say that he had an egr block off so wouldn't that pretty much negate him having to get studs?
EGR has nothing to do with tuner and stud relations. A tuner is going to raise cyl.preasure on a already weak head bolt layout design. For some stupid ... reason the 6.0 had a reduction in the number of head bolts surrounding each cylinder. Basically it has 4 bolts per cyl. for a total of 10 bolts for compression purposes, compared to the 7.3 which has 6 bolts per cyl. total of 18 bolts, remember some inner bolts are used for two cyl's thats why total numbers are lower. Plus the type of bolt used doesn't help. I dont like "TORQUE TO YIELD" bolts, I've seen tooo many failures in this bolt (ALL-THREAD) design sense the mid 90's in gassers that dont have our compression
