Diesel Forum - TheDieselStop.com - View Single Post - Running a Power inverter off my truck
Old 12-19-2009, 09:05 PM   #27 (permalink)
knoweigh
knoweigh's Avatar
Originally Posted by DHTD View Post
Knoweigh,
I looked at your setup, very nice!
Did you connect one battery to the left battery in the engine compartment, and another batt to the right battery in the engine compartment? Or did you tie both auxillary batteries together and run positive and negative to 1 battery in the engine compartment? Sorry for the rookie questions, just dont want to fubar this up.
Thanks.
I have 2 batteries in the wooden box underdeath the inverter (they're hidden)
Those 2 aux batteries are tied together & charged via high temp 4ga red and 4ga black wire through the slit loom on drivers side and are tied into only the driver side engine battery. (I was able to use 4ga since this is simply a "charging feed". If I wasn't running aux batteries, then I would've needed 2-runs/ea of 2/0 cable.....about 60ft of wire. Thus, in my mind, 2 aux batteries were actually cheaper than the large cable that I would've needed AND provides me w/ more power)
The 2 batteries in the engine compartment are tied together so if you went to either battery that would be sufficient; no need to run your inverter wires to both engine batteries.
Hope this helps.
best of luck.
y2k F250 7.3 psd Calif emissions, ext cab long bed 265/75/R16 E rated tires, 190k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode 4R100, Dp tuner stock, 60t 60e 80t 80e, high idle. DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed uppies, 4" downpipe & exhaust, 203t-stat, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags, BTS VB, Sports a Western plow when the white stuff flies.
Trailers:
I'm usually towing 1 of several trailers I've built.
15ft car hauler (1000lbs empty; 5500lbs loaded)
26ft deck over car hauler (2000lbs empty; 7k loaded)
36ft car hauler (Was tongue pull; have since converted into 5er'. 4500lbs empty; 14k loaded)
https://lh5.googleusercontent.com/-g...0/IMG_4130.JPG
knoweigh is offline   Reply With Quote
