I have 31s in my truck. I did have to do some mods but it was nothing too difficult. I just installed my second set a month or so ago. My first set lasted me 5 years to the month. There is adjustment in the battery trays that you can move them down further and then they aren't as wide so I stuffed a piece of plywood behind them to hold them in tight and wrapped a bungie strap around each of them.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
