Diesel Forum - TheDieselStop.com - View Single Post - 4x4 not working
Thread: 4x4 not working
Old 12-22-2009, 08:19 AM   #8 (permalink)
rock_doctor
rock_doctor's Avatar
That is really the best way to do it. When i need 4wd i just manually lock the hubs and then click the dash switch for the transfer case. When i got my 08 i went with manual hubs and manual transfer case. As a side note, when you get air out the defrosters it means there is no vacuum. That generally means either the hubs are leaking vacuum or a hose is leaking/came off. The defroster is the default if there is a loss of vacuum in all automotive ac/heat systems. You can disconnect the hubs and plug the lines. if you have vacuum then hubs are leaking. If still no vacuum then there is a hose or pump problem.
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline   Reply With Quote
