I doubt the issue is related to the Companion itself... I use the Companion in my truck and have no issues with jerking.. Did you change wheelbase lengths when you moved to the 08?? If your Companion is further back on the 08 than it was on the 05, it leads me to believe the actual hitch (the part attached to the frame) is mounted further to the rear on the 08. Typically, this is done with the shortbeds. If both were longbeds, then I would suspect the hitch itself was installed in the wrong location..
 2003 Toreador Red/ Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
pics
#43
SLAPS President and Webmaster
