A p040d code is for when you pcm reads a voltage above what it thinks it should for five seconds or more, I think 4.65v is max. I wouldn't think 1350 would be bad while pulling a hill. How is your EP, if you still have all your DPF you may be starting to clog. Or you may have wiring problems because of the code that you are getting
