Diesel Forum - TheDieselStop.com - View Single Post - Split second loss of power
Old 01-18-2010, 05:29 PM   #9 (permalink)
Fomoco365
Originally Posted by IH81 View Post
I have an 02 Ford F250 and occasionally when it is cold it will miss a little bit when I get in the throttle, but mostly it seems like it will lose power for a split second and then everything is fine again. It will do it on occasion when it has warmed up, but most of the time it is when it's cold. Has anyone had a problem like this? I have been told it could be the cam sensor but I always heard that wasn't intermittent, they just go out....Any ideas?
Thanks!!
Does the truck have a chip? If so, check to see if it is loose.
If no chip, I would check the nut on the ipr valve and the cmp sensor and connector as previously mentioned.
Fomoco365 is offline   Reply With Quote
