Latest TSB for Head Bolt Torque Sequence???
21K views 4 replies 3 participants last post by  joshr33
#1 ·
Anyone know where to find the latest TSB for Head Bolt Torque Sequence? I have the original from 02/03 however I’ve heard it has been updated since then. By the way this will be for installing studs…
Thanks,
JR
#2 ·
Okay folks, since nobody wanted to touch this one here are the recomendations from ARP for their studs...
ARP...
Tighten the head bolts in the following sequence.
Tighten bolts 1 through 10 to 65 lb-ft.
Tighten bolts 1 through 10 to 100 lb-ft.
Tighten bolts 1 through 10 to 150 lb-ft.
Tighten bolts 1 through 10 to 200 lb-ft.
Tighten bolts 1 through 10 to 245 lb-ft.
Tighten bolts 11 through 15 to 24 Nm (18 lb-ft).
Tighten bolts 11 through 15 to 31 Nm (23 lb-ft).
I've also attached the latest updated bolt sequence & torque values for Ford's TTY Bolts from the Ford Shop Manual... Hope this helps everyone...:thumbsup:
JR
#3 ·
good post. thanks.
#5 ·
Campingtom, I’m only a couple of hours away so let me know if you need any help…:thumbsup: Plus I got family north & south of you that I can send the wife and kido's to.:jester: My new heads arrived yesterday and the black-o gaskets should be here today so going to be an eventful weekend.
JR
