Diesel Forum - TheDieselStop.com - View Single Post - Building a truck frame up elec q's
Old 02-08-2010, 01:00 PM   #2 (permalink)
arthurgoboom
arthurgoboom's Avatar
You need to keep the diesel instrument cluster if you want to still have a tachometer, and I'd keep the small module that houses the diesel specific indicator lights (glow plug, water in fuel, engine temp). There are no other controls or anything for the engine or trans.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline   Reply With Quote
