My viper 791xv will try to start the truck as soon as the glow plugs finish their cycle, if it does not start the first time then it waits 60 seconds and tries again. 2 glow plug cycles, with 2 start attempts.
Late 99 SD PS CC SB 4x4 Lariat. 7.3l TS 6xchip Stock-140hp , Banks 6gun, Full Banks Gauges, 4"SS turbo back exhaust, UMP Intake w/ Donaldson Filter, Auburn posi F&R 3.73, ATS Trans W/ 5Star converter and CoPilot, 18k trans cooler, Dynatrac FreeSpin front hub kit, ITP oil X over, ITP boost regulator, Aero Fuel Tanks Replacement 55 Gallon tank, New timing cover,oil pan,oil cooler, water pump,turbo petastel, reman HPOP, new fuel filter housing, slotted brakes all 4 corners W/ Ceramic pads, Adjustable trac-bar, Front 1.5" level kit only. 226,000 miles 10/1/09 Best mpg 27.3..Norm city 15 mpg hwy 20+
Early 99 CC LB 2WD Manual 6....Stock 228k (11/09) and running strong, only repairs Clutch, water pump, alternator. K&N FIPK since 36k and loving it!
2006 CC LB 4WD Lariat 6.0l 5R110 Stock 178k (12/09) "Dad's" 3 injectors and GP harness(12/09) Dynatrac Ball Joints, New ERG and 2 injectors (6/10)
