Diesel Forum - TheDieselStop.com - View Single Post - Need help Identifying a sensor/sending unit
Old 02-15-2010, 09:19 PM   #3 (permalink)
meachamp
Originally Posted by dray8165 View Post
Yes it is - that is your ICP sensor (Injection control pressure sensor) It is very common to leak.
I can't find it on the page, but I'm sure they have them - you might have to call. It is the same size as the high pressure oil lines.
Replacement O-rings for Ford Diesel Engines
Is it hard to change?, and this is the one behind the HPOP/Fuel filter area right?
2011, F350SD, 4x4, Crew Cab, LB, King Ranch, Forest Green, w/Gold accent lower, 6.4L Auto, Power everything, Catch all mats all around and custom Wet Okole set covers, 20" stock tires and wheels.
meachamp is offline   Reply With Quote
