Oil level is good. New battery in Nov last year it tested good today, other battery was replaced today. Truck acted like battery was dead on Mon and wouldn't start and wouldn't take a jump. It wouldn't turn over. I figured it was the starter. After work I pulled the starter took it to auto parts store and tested it on the bench. It worked. Went back and put it back on. This time could hear the starter motor spinning but wouldn't crank the engine. Used a screw driver to jump the starter relay on fender wall and got same result. Thought maybe the starter was spinning but not extending to turn fly wheel. We took it back off and back to store to test it. The pinion extended and spun. Reattached the starter turned the key and nothing but a click. Same result at the relay. Checked voltage at relay, starter, batteries all the same. This morning tested the batteries and replaced the bad one. Turned the key and got the same click.
