After doing some testing it appears that there is continuity between the frame and the power which I assume is what is causing everything to go crazy.. Ive been doing a lot of reading could the gem or fuse box maybe be shorting and transferring power to ground somehow? Im also assuming this is because of the rain because I am getting water dripping down from around the gem/fuse box.
I apologize if I'm jacking the thread 2fastc I figured our problems are similar maybe mine is being caused by the same thing so it could help both of us.
