Diesel Forum - TheDieselStop.com - View Single Post - What to watch for......
Old 03-14-2010, 03:25 PM   #2 (permalink)
wldwilliam
wldwilliam's Avatar
Originally Posted by Cowcop View Post
One of my friend's sons has purchased a 2005 F350 Auto with the 6.0 Liter diesel...I will also be encouraging the young fellow to start checking out this site.
The best thing you can do is point him here and have him browse this forum for a day of two. He may get freaked out a little because so much of the discussion is about problems with the 6.o but he will gather a ton of knowledge about good maintenance practices and helpful mods to increase engine reliability. Send him here!
Of course, you could browse the forms for a couple days and translate for him
2005 F350 | Lariat | CrewCab | 4x4 | 6.0 | 5 spd auto
Edge Insight & ScanGauge II monitors | Autometer FP gauge | DieselSite Coolant Filter | DR 2.5" level
18x10 Weld Evo Cheyenne 8 | 325/60r18 ProComp XAT | Upfitter Switches added | Extang Trifecta Tonno
Amp Research PwrStp | high idle mod | Ford F/P reg mod | latest EGR valve
03/06, 9K miles
oil leaks (r&r rear main seal and cam sensor), recall 05E16 (ECM recalibration), recall 05B32 (de-gas bottle fill level label applied & coolant level adjusted)
06/07, 22.5K miles
no 4x4 (r&r left side vacuum hose), e-brake malfunction (r&r parking brake ratchet assembly)
01/10, 30K miles
oil leaks (r&r bed plate, rear main, rear cover gaskets & o rings), CEL (r&r reman turbo, drain tube, update processors)
03/10, 30.5K miles
EOT +15°>ECT (r&r oil cooler, egr cooler, degas bottle & cap)
[all under warranty]
wldwilliam is offline   Reply With Quote
