100 grand on my baby and want to work on it myself, think i have an injector going and would like to monitor better , no gauges yet , no mods except for air intake Which one ? Larry
If you're looking for diagnostics, AutoEnginuity is the way to go IMO. The Edge Insight will monitor some parameters, but with AE, you can record up to the capacity of the hard drive on your laptop. I've recorded runs of 5 miles to get a handle on issues. AE will do nearly everything that Ford's scan tools will do, except the contribution test on the 6.0L that Ford won't let out.
If you're looking mainly for a gauge package, with some diagnostics ability, then maybe the Insight would be a better value.
I ordered the AE from Clay @ Riffraff. Hooked it up for the first time the other day. There is so much information you can obtain. I was extremely amazed at all the sensors available. Shoot, you can even monitor when your brake pedal is pushed.
If you are going to use it to troubleshoot problems then get the AE. If you just want an all in one gauge to constantly monitor egt, oil temp, etc... then get the edge. The downside to the AE is that you have to have your laptop hooked up to it and you don't want to power it from your truck (something about a ground loop). So, you better have a good battery in your laptop if you plan on driving with it.
might also look into the dash daq. the ae is hands down the best scan tool but the dashdaq can read alot more stuff than the edge and read more trouble codes as well. and still be a good set of gauges
ITP Diesel is a site vendor that sells them. I don't know if they offer free shipping though. Same price as Riffraff diesel (but they have free shipping). You need the Ford Enhanced bundle. Just shy of $360..
Yes, the updates are downloaded directly from AE. When you first get it, you need to get an activation code from them to get the Ford Enhanced part to work. They'll then have you on their database. I think the seller may also report user info to AE as well.
If you go the dashdaq route, where is the best place to buy from? Does Spartan still do a special Ford 6.0l Custom programmer Dasdaq?
Related Threads
The Diesel Stop
2.6M posts
211K members
Since 1999
