Diesel Forum - TheDieselStop.com - View Single Post - Possible Turbo Problem?
Old 03-21-2010, 10:52 AM   #3 (permalink)
Patrick Feeley
Patrick Feeley's Avatar
My Photos: (19)
You can always temporarily elcetrically disable the Exhaust Back Pressure Valve (EBPV) by disconnecting the 2-wire weatherpack connector near the base of the turbo on the driver's side. If your problem goes away when cold, your EBPV is probably just acting normally. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline   Reply With Quote
