Diesel Forum - TheDieselStop.com - View Single Post - Changing ATF: 7.3L PowerStroke Engine and 4R100 Automatic Transmission.
Old 05-29-2010, 10:21 PM   #4 (permalink)
Duzitall
Here's another tip:
Be ready for about a pint of fluid to come at your head when you pull the filter loose.
2002, F350, Lariat, CC, LB, PSD, QLJ5, A/T, ESOF(with hub disable switch), LS, Off Road pkg, AIC, Jordan 2020, X-monitor, IAH removed, Fuel pressure shimmed, DP-Tuner 80 econo, acetoned badges, 315 BFG's on Alcoa's, 4"DPPI exhaust, Sonnax/Tricumulator, DIY BIG air filter with ZooDad, Bilsteins, EBV removed, WW, Proflex SS sleeves over the orange manifold hoses, MAP connected to adjustable pressure regulator, EBPS connected to intake manifold, Red line disconnected, Modified factory wastegate, 200 amp large case alternator, AutoEnginuity, Chris Thompson, SoCal Biodiesel Users Group member, Soon to have a bunch of goodies from Riffraff Diesel.
Duzitall is offline   Reply With Quote
