This summer I am going to rebuild my front end. I have already replaced the rotors and the wheel bearing set once. Seals and now shot and ball joints are showing wear. My question is I am collecting the required parts I cannot find the schematics in the online Ford Parts Websites. I could find them before but not now. Without the schematics I am not sure what part #'s I need. Could someone direct me to a website with the schematics or could one of you Ford employees provide a Ford catalog Part # list of required parts? It is a June 99 productions date.
Wheel Bearing set
Thrush washers
Ball Joints
Back seal
Axle shaft seal
Tie rod ends
Am I forgeting anything? I swapped out the front hub for Warn Premiums.
Thanks for the help.
Wheel Bearing set
Thrush washers
Ball Joints
Back seal
Axle shaft seal
Tie rod ends
