Re: WVO tankage
I am not sure how thick vegetable oil is when cold, but couldn't you run the WVO line through the factory trans cooler on the side of the radiator? At least for the pre 99 guys?
Only the autos have a trans cooler, and I think it's always mounted on the bottom of the radiator.
How are you suggesting that the fuel line be run through the cooler?
2003 F350 SRW Crew Cab 6 liter PSD, Torqushift Transmission, 4x4, 606,000 kms
1996 F250 XL, Powerstroke, Swamp's Baby injectors and TS 3 position chip, Tymar intake and downpipe, 4 inch straightpipe, amsoil engine oil bypass filter, coolant bypass filter, 203 thermostat, chevron synthetic oils front to back, 4x4, 5 Speed, Luk single mass flywheel
382,000 kms
