Re: WVO tankage
Using coolant, the stuff is already hot and doesn't use up any extra energy.
Except I don't think my engine will run 180 degrees in the winter, even with most of the radiator blocked. Without a cover, it barely touches the bottom of the "NORMAL" range on the gauge, & throws almost no heat. I think MOST diesels have this problem. Figuring out an electric heater might be easier than figuring out how to keep the engine 180+ degrees in January.
1979 F-350 4x4, Cummins 6BT power
1992 International Genesis school bus conversion
GO, RED SOX!
