Diesel Forum - TheDieselStop.com - View Single Post - Truck not running correctly
Old 07-29-2010, 11:25 AM   #7 (permalink)
woodnthings8
woodnthings8's Avatar
Those pins are located on the PCM connection. It is a 104 pin connector that it mounted to the PCM just below the Brake Master Cylinder on the firewall. You will need to unscrew the 10mm bolt to disconnect it (NO KEYS IN THE IGNITION).
This is where a breakout box comes in handy, You install it between the connector and the PCM and you can just use your meter to check it while it is running.
Here is the layout of the connector.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline   Reply With Quote
