Diesel Forum - TheDieselStop.com - View Single Post - Truck not running correctly
Old 07-29-2010, 10:19 PM   #11 (permalink)
woodnthings8
woodnthings8's Avatar
Check continuity on pin 21 of the connector mounted to the drivers side valve cover. That is the VREF 5 Volt signal to the ICP, Oil Temp, EBP, and ACT Sensors.
I 'm thinking if you have VREF to those, you may have a break in the wire somewhere on the engine.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline   Reply With Quote
