Originally Posted by dgorczyca
Okay, so I tested pin 19 on the 42 pin connector with the key turned on. There is no voltage coming from the PCM. Does this mean the PCM is junk?
Not necessarily. It could stil be a wiring issue. Those can be a PITA to find. If you have a buddy with a very similar truck (preferrably same PCM code), you could try swapping PCM's. If the problem goes away with his PCM in your truck, then it's your PCM, if it doesn't , then you'll have to track down the wiring issue.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
