Diesel Forum - TheDieselStop.com - View Single Post - Heating return line?
Old 06-23-2004, 03:48 PM   #6 (permalink)
The Warden
My Photos: (24)
Send a message via ICQ to The Warden
Re: Heating return line?
Lob, your plan to put a third tank in the bed makes sense...I"d probably go that route myself, except that I don't want to lose any more bed space than I already have. I fill my bed up to capacity on a fairly regular basis...
The idea of routing both fuel lines through a conduit of sorts makes sense. Do you think that the lines wrapped around the fuel feed (like Greasel's three-way-hose setup) would heat up the return line as well?
when the fuel runs thru the engine block fuel passages it heats things up quite a bit!
...except that IDI's don't have the engine block fuel passages that PSD's have. [img]/ubbthreads/images/graemlins/smile.gif[/img] All fuel lines on an IDI are external, except for the injectors themselves...
The Warden is offline   Reply With Quote
