Re: Heating return line?
Yeah, but will the average black rubber hose conduct heat enough (especially through two layers) to heat up the fuel enough to really help? I at least thought that the big advantage with the Greasel setup was that they use thin plastic that radiates heat better.
Or can plastic fuel/coolant hoses be readily acquired? BTW, if this makes a difference, I've got metal fuel lines right now (they switched to the plastic lines with the quick-connect fittings in '85)...
