Diesel Forum - TheDieselStop.com - View Single Post - Another convert and NO HEAT!
Old 06-24-2004, 12:48 PM   #7 (permalink)
TCH777
My Photos: (18)
Re: Another convert and NO HEAT!
Okay so the reason you can't rev good past 2500 is the WVO is too thick if it is not heated. Your fuel system and oil system can't reach the right pressures to move, inject and atomize the WVO properly. I think you are running on borrowed time if you don't get a heater on your truck for the oil!
The VO does not harm the injectors per say. But if it is not heated and burning cleanly then it will choke up the injector nozzles. Also it could choke up the pistons and rings. But I suppose if the injectors are run long enough on a VO that is not the correct viscosity then they might become damaged over time from added stress.
It is cool you gave this a try but I don't think it is a good thing to do for long term. If you are not going to add a heater to the WVO then go back to a 50/50 blend. I would hate for you to much up your injectors, oil system, fuel system or engine.
Tim
2001 F-250 Crew Cab, short bed, 4x4, 4R100 with VB tuned by Travis's Automatic Trans, Lariat, Snugtop shell, Line-X bedliner, 265/75/R16 GY Silent Armor. DIY open element air filter. DIY 4 inch exhaust, from stock DP back to 45 degree turn down. Quadzilla Recon XZT moniter- EGT, Trans temp, Boost. DP tuner Stock, 40T, 40T high altitude, 80E, Curt MFG Q5 20K slider hitch, P3 brake controller, ATS housing. Blue Bullet
Sold-- Bright RED 1996 F350 XLT, 4X4, CC, 4.10 gears ,E40D, SRW, Rebuilt E40D at 190K with a 3yr/36K mile warrenty, by Travis's Auto Tranny 719-574-8104. Big Red
Proud Member of the NRA, helping to protect our American Rights!
New Toy: Can-Am Outlander MAX XT 650 -- AWESOME
5th wheel 2000 Dutchman 24RL with 12' slide
TCH777 is offline   Reply With Quote
