Haven't seen a 2001 but should be the same as a 1999. Shifter lever with OD button is $58 at dealer. Three phillips head screws underneath the steering column holding the cover, remove it, then to remove the key cartridge, there is a pin bottom side of key, push it up and pull cartridge out, top cover comes off then, one pin or bolt holds the shift lever in, unplug connector. If the wire is bare just repair it or install new lever. Check it out before buying new lever, don't take long to do.
bringing up an old one. I keep blowing this fuse. Finally pulled the column covers today, and the wiring looks fine.
So is the shifter itself going bad? Something internal that I can not see? Does not hapen when depressing the OD button. So far only while at idle, thankfully
Sometimes it is difficult to see the chafe point. I have even seen the wires fail right where they enter the shifter stalk. Typically the short occurs when shifting from park to drive and the wires are moving. I see them chafe on the upper shift tube where they drag across and also on the shifter opening boot bracket.
that was it. I pulled the little leather dust cover thing and it was up in there. Got it all worked out. Thanks
Related Threads
The Diesel Stop
2.6M posts
211K members
Since 1999
