Diesel Forum - TheDieselStop.com - View Single Post - Early '99 Engine Wiring Harness Part Number
post #3 of (permalink) Old 07-07-2011, 07:57 PM
klhansen
klhansen's Avatar
My Photos: (180)
Originally Posted by DaveBey View Post
Does anyone have the Ford or International part number for the main engine wiring harness for an early '99 Power Stroke? This is the 42-pin harness connecting to the engine sensors and valve cover gaskets. I've tried site and Google searches with no avail. Thank you!
Cheers from Claremore, OK!
Dave
I did a quicky search and didn't come up with much for you, Dave.
I think you could use a 99.5 or later harness and just not connect the extra stuff like the IAH Relay. Everything else should be pretty much the same. You'll need to match yours for other features like AC/No AC, Dual/Single alternators, and probably something else that I can't think of right now.
Unless yours is totally burnt up, repairing it might be the better route as opposed to finding a new replacement. Have you tried the wrecking yards (although they are usually reluctant to sell engine harnesses)?
The PN sticker should be right behind the alternator near the lifting eye, if the sticker is still there.
Mine is 1807461C91 Rev 87694X1 AFL. No AC, & single alternator. Build date 1/99 so what you're looking for should be one of the three prior to that number in this list.
F81Z 12B637 AB NAVISTAR-1807399C95 WIR ASY-ENG CONTR SNS & FU
F81Z 12B637 BA NAVISTAR-1807400C96 WIR ASY-ENG CONTR SNS & FU
F81Z 12B637 DA NAVISTAR-1807460C91 WIR ASY-ENG CONTR SNS & FU
F81Z 12B637 EA NAVISTAR-1807461C91 WIR ASY-ENG CONTR SNS & FU
F81Z 12B637 FA NAVISTAR-1837761C91 WIR ASY-ENG CONTR SNS & FU
XC2Z 12B637 EA NAVISTAR-1807463C91 WIR ASY-ENG CONTR SNS & FU
XC2Z 12B637 FA NAVISTAR-1807462C91 WIR ASY-ENGINE
YC2Z 12B637 GA NAVISTAR-1831743C92 WIR ASY-ENGINE
YC3Z 12B637 AAA NAVISTAR-1807467C92 WIR ASY-ENG CONTR SNS & FU
YC3Z 12B637 BA NAVISTAR-1831742C92 WIR ASY-ENG CONTR SNS & FU
YC3Z 12B637 EA NAVISTAR-1837762C91 WIR ASY-ENG CONTR SNS & FU
1C3Z 12B637 AA NAVISTAR-1837760C91 WIR ASY-ENGINE 1837760C91
1C3Z 12B637 BA NAVISTAR-1837753C91 WIR ASY-ENGINE 1837753C91
1C3Z 12B637 CA NAVISTAR-1830882C91 WIR ASY-ENGINE 1830882C91
1C3Z 12B637 GA NAVISTAR-1838083C91 WIR ASY-ENGINE 1838083C91
BTW, this came from your old FAQ downloads here: http://www.thedieselstop.com/faq/949...nterchange.pdf
Hope that helps.
), AIS,
regulated return,
klhansen is offline
