I have never heard that there is a code that the computer registers for low FMP voltage. I've certainly heard of people with FMP voltage down in the 30's and no code. Fuel pressure is definitely the main killer of injectors, as far as I am concerned. It needs to be tested with a Ford bypass pressure tester that simulates full power fuel flow.
Brian
The Dec 2009 Ford flash will throw a P0611 code for low FICM_M. This is a "soft code" and wont through the wrench light. This flash also throws a code and the wrench light for EOT to ECT deltas.
Here are the details:
TSB 09-24-3 6.0L DIESEL CALIBRATION UPDATE - VARIOUS ISSUES
Publication Date: November 20, 2009
FORD: 2003-2005 Excursion
2003-2007 F-Super Duty
2004-2010 E-Series
This article supersedes TSB 9-7-11 to update the model years covered and Integrated Diagnostic System (IDS) calibration level.
ISSUE:
Some 2003-2007 F-Super Duty vehicles, 2003-2005 Excursions and 2004-2010 E-Series vehicles, equipped with a 6.0L diesel engine may exhibit hard start, no start, white smoke, lack of power, running rough condition after cold engine start up, or diagnostic trouble codes (DTCs) P0404, P0470, P0611, P1260 and/or P1378 issues. Refer to the Calibration Content for information detailing specific vehicle content by vehicle application and model year that is being addressed by this calibration update.
This article includes previously released calibration content that improves injector performance in cold engine operation and additional diagnostic capabilities and product
[COLOR=blue !important][COLOR=blue !important]protection strategy[/COLOR][/COLOR] enhancements. These enhancements provide additional diagnostic capabilities, adds additional new DTCs and engine protection strategies. Refer to the Calibration Content for additional details. See the appropriate Powertrain Control/Emissions Diagnostic (PC/ED) manual for technical descriptions and diagnostic routines associated with new DTCs.
ACTION:
Reprogram the powertrain control module (PCM) using IDS release 63.13 and higher or 64.01 and higher. The
[COLOR=blue !important][COLOR=blue !important]transmission control[/COLOR][/COLOR] module (TCM) and fuel injector control module (FICM) , will automatically update if they are not at the latest calibration level. This new calibration is not included in the VCM 2009.11 DVD. Calibration files may also be obtained at
MOTORCRAFT PARTS FOR FORD, LINCOLN OR MERCURY VEHICLES.
CALIBRATION CONTENT
Reprogram the PCM to the latest calibration following Workshop Manual (WSM), Section 418-01.
The PCM and FICM calibration update contains improvement actions to address the following symptoms:
2005 F-Super Duty 6.0L:
False DTC P0470 - Exhaust pressure sensor A circuit fault due to a freezing condition.
False DTC P0404 - Exhaust gas recirculation (EGR) performance due to a stuck turbocharger condition.
Cooling loss protection - Revised engine protection strategy when an engine over-temperature condition is present. Vehicles updated with this service calibration will display higher temperature gauge readings when high
[COLOR=blue !important][COLOR=blue !important]engine oil[/COLOR][/COLOR] temperature (EOT) conditions or high engine coolant temperature (ECT) are encountered and may disable EGR operation to prevent possible EGR cooler damage.
Oil cooler efficiency monitor - DTC P012F stored and
[COLOR=blue !important][COLOR=blue !important]wrench[/COLOR][/COLOR] warning lamp illuminated when the oil coolers efficiency drops below a specified threshold for a given speed and vehicle load condition.
Turbocharger vane sweep strategy - Performs a sweep of the turbocharger vanes and unison ring during stationary idle conditions. Vane sweep can occur once per hour to help reduce turbocharger sticking.
FICM low voltage detection monitor - DTC P0560 stored and wrench warning lamp illuminated when PCM vehicle power (VPWR) parameter identifier (PIDS) is below 10.25V for 60 seconds or below 9V for 4 seconds.
Turbocharger over boost detection - DTC P0234 stored and wrench warning lamp illuminated when a turbocharger over boost condition occurs.
2006-2007 F-Super Duty 6.0L:
False DTC P0404 - EGR performance due to a stuck turbocharger condition.
Cooling loss protection - Revised engine protection strategy when an engine over-temperature condition is present. Vehicles updated with this service calibration will display higher temperature gauge readings when high EOT conditions or high ECT are encountered and may disable EGR operation to prevent possible EGR cooler damage.
Oil cooler efficiency monitor - DTC P012F stored and wrench warning lamp illuminated when the oil coolers efficiency drops below a specified threshold for a given speed and vehicle load condition.
FICM low voltage detection monitor - DTC P0560 stored and wrench warning lamp illuminated when PCM VPWR PIDS is below 10.25V for 60 seconds or below 9V for 4 seconds.
2005-2007 And 2009-2010 E-Series 6.0L:
False DTC P0470 Exhaust pressure sensor A circuit fault due to a freezing condition.
False DTC P0404 EGR Performance due to a stuck turbocharger condition.
2008 E-Series 6.0L:
False P1260 induced during cranking due to low battery voltage.
Generic on-board diagnostics (OBD) improvements including; Mode 1, Mode 2, Mode 4 and J1699 OBD data test results as reported to the service tool.
Previous released calibration content included in IDS software release 48.2 or higher for: 2003-2007 F-Super Duty, 2003-2005 Excursion and 2004-2008 E-Series 6.0L diesel equipped vehicles:
White smoke, lack of power, running rough condition after cold engine start up due to injector spool valve sticking internally during cold engine operation.
No start/hard start when accompanied with DTC P0611 (FICM Performance), P1378 (FICM System Voltage Low) and/or all eight (8) injector circuit codes.
The new calibration changes the frequency of injector spool valve shuttling under certain conditions and will sound differently from previously released versions.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
092403A 2004-2010 Econoline, 2003-2007 F-Super Duty, 2003-2005 Excursion 6.0L: Check For DTCs And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 0.6 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
RECALEM 04
