Diesel Forum - TheDieselStop.com - View Single Post - PS2000 Finished
Thread: PS2000 Finished
Old 03-02-2005, 05:12 PM   #26 (permalink)
beretzs
beretzs's Avatar
My Photos: (13)
Re: PS2000 Finished
I thought I had it, but by the time I was halfway home I was blowing coolant and it was still hammering (very slight) at upper boost and RPM ranges. I already backed it off about a 1/2 turn, and want to wait for the turck to cool down so I can see how much coolant I lost. Pretty minor stuff in the whole scheme of things. Hopefully by this weekend I will have it tuned enough to run on a dyno. If backing it off the 1/2 turn doesn't help, I will look at backing off the timing incremently and see what happens. Anyhow, I will continue with the messing until it is straight. The power is really there. Again, for you guys that need that little extra, propane is probably the easiest and cheapest way to go, because you can use it when you want and if you don't need it, don't turn it on. Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
beretzs is offline   Reply With Quote
