Re: Just had Rear Main Seal Replaced
Dropped my rig off Tuesday morning, was told I'd see it again Thursday evening. To my surprize I got it back today at 15:00.
The job paper states: Oil drip from the back of the engine to bellhousing. Verify customer concern, remove trans, replace rear main seal and reseal bed plate. Reassemble and retest ok.
Also: Belt or pully squeek on cold start up. Replace serpintine belt with update to correct.
I have 35,477 miles on this truck. I had the new turbo pedestal installed after the turbo was replaced (at 250 or so miles) to correct the "moan" at 1700 rpms.
The new pedestal moved the "moan" down the rpm scale and you can feel a vibration in the floor. There's a revised procedure to loosen up the exhaust system, check and/or reline the pipes and retorque it all. The Tech that's going to do the job (the Tech that's done all work that has been done to my truck) said he's done four of these and one solved the "moan" and the other three didn't help. He's going to redue my truck Tuesday. We'll see if it's any better.
To me these are minor problems execpt for the rear main seal. They don't put the amount of time spent on the job doing these repairs so we/you can figure what it would cost us out of pocket to replace a $35 seal.
I was told that replacing this seal is part of the 100,000 mile power train warranty so if it goes out again it's covered. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2004 SD F-250 4X4 Supercab 6.0 - TorqShift
Dark Green Satin Arizona Beige Met Accent Lariat 142" WB Styleside Pkg 608A, 3.73 LS 8800# GVWR, Electronic Shift on the fly, Telescpng TT mirr-powr/HTD, FX4 pkg, Skid Plates, Adj. Gas/Brake Pedals, Reverse Aid Sensors, Hitch Reciever 15K, Heated Seats - Ford bed liner - EGR Bug Deflector - Window vents - Billet grill - Mud Flaps - Locking Fuel Cap - Bull Ring stake pocket tie downs - Isspro gauges EGT, Trans Temp, Turbo Boost, Cubby Gauge pod - Sirius Radio - Rancho RS9000X Shocks
1995 Green Taurus SHO mini-mods
1988 Arrest Me Red Corvette 380rwhp many mods
