03-01-2005, 09:52 PM
#1 (permalink)
Turbo PSI vs. Boost
Ok , everyone talks about airflow and max psi for psd (40-45psi before gaskets blow) but psi is pound per sq. in. wouldn't you want to measure max flow in cfm cubic ft. per min.
for ie. if you force 1200 cfm through a 3" pipe you have a psi fo let say 35 pounds. if you pass that same volume of (1200cfm) air though a 4" pipe you should have a psi of some thing like 20 pounds.
my point is that you can't compare psi from one turbo to the next _ htt to gtp38r, to he2. to make a proper selection of turbo for my aplication i need to know cfm right?
Long Island Performance Diesel & Fuel
Coram, NY 11727
631-285-1174
http://www.longislandperformancediesel.com
PRODUCT LINE: High Tech Turbo, ARP, South Bend Clutches, SunCoast Transmissions, MBRP Exhaust Systems, Silverline, Magnaflow, Bullydog, Banks, aFe Intake Systems, Airaid, ISSPRO Gauges, Autometer Gauges, BD-power Superchips, Edge Products, Dp-tuner, BDP Injectors, Quadzilla and more... Call 631-285-1174 discount pricing.
