Re: 16' or 18' car hauler?
99% of the time, the dovetail is going to be the same length. on a 16' trailer you have 14' flat + 2' dovetail ... on 18' you have 16' flat + 2' dovetail. but you can special order anyway you like, most trailer mfg. will build to suit. a "true" car hauler is built lower so bottoming out usually isn't an issue.
Around here trailer dealers have 2' and 4' dovetails all the time. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
My tubbed and narrowed race car is pretty low and did scrape on my buddies 16' with 2' dovetail. Not on the 18 w/ 4' dovetail. Guess I need to raise my racecar. [img]/ubbthreads/images/graemlins/smirk.gif[/img]
Remember, this is the internet, where everyone's a diesel mechanic and has 500+hp/1000+lb/ft under the hood! Read up, form your own opinions, then do your own real-world testing!
'01 PSD F-250 XLT SC LB 2WD 6SPD 3.73LS, Alliant AC's,ARP Studs, Stealth Dual HPOPs, GTP38R, Forged Rods balanced, Fluidampr, South Bend CON OFE, 6.0L Intercooler, Volant Intake, 4" SS MBRP Exhaust, A-Pillar mounted Lunar Series Boost/Pyro Gauges,4 pos. Chip with Stealth burns from Twildman, playing with Minotaur Tuning software too, heated Racor 900FH 2 micron, Hutch mods, harpoon mod, DIY Regulated Return, 203 T-stat, coolant filter, AIH gone, CCV Mod, boost pressure relief valve, 100 gallon tank/toolbox combo...AutoEnginuity diagnostics for all Domestics
