Re: lowering 4by4
i had the very same problem as you. my original blocks were 4". ford removed them all together, which made the back sit lower than the front, looked like crap and caused driveline vibration. they then put 2" blocks in and i think had to shim the carrier support some, everything is fine for me now. my 5'er has adjustable spring shackles and i have it set to the tallest position. hope this helps.
2008 f350 crew cab lariat 4x4 v10
previous: early 99(6/98) f250 xlt 4x4,psd,xle4,auto,sc,lwb.
99.5 air box, scorpion spray in bedliner, isspro ev pre-turbo pyro,trans,and boost,a-pillar mount. rancho rsx shocks,
superchips microtuner(2 program), magnaflow 3.5" dp 4" back exhaust, zoodad mod,
31' jayco 5'er
