Re: Brake Controller
I mounted my controller in the cubby hole also. I used bullet connectors (in conjunction with the factory supplied harness) when I wired up the controller, so that I only had to drill a hole large enough to fit the wires through and not the connector. I drilled up at the top of the cubby hole and you cannot see it without crawling in the floorboard and looking for it. It works great and the bullet connectors make for a quick easy removal (never actually had to remove it). I'm like you though, I hate making permanent interior or body modifications.
2002 Super Duty CC Lariat 4x4 4.5" Donahoe Racing lift
