Diesel Forum - TheDieselStop.com - View Single Post - does zf5/1356 have pto
Old 03-05-2005, 06:39 AM   #6 (permalink)
twin_diesels
Re: does zf5/1356 have pto
Well,in my experience, you can hook about anything you want up to it. I know a few places that use this chassis for a fire truck have connected a small fire pump to these ports. What you need to look into is how much force can be run through these ports versus how much force is needed to run the accessory. PTO's typically won't take the full the force that is produced by the motor. Also, you need to make sure the PTO that bolts on is the right gear ratio to run whatever accessory you are looking at. The name I typically see on fire apparatus is Chelsea. They've been around a long time, and could help you get your hands on a PTO as well as make sure the application is correct.
Proud Dad (0wner) of 2 IDI's and a Cocker Spaniel Mix. A the IDI's are both F250, 4x4, 5spd manual, standard cab, long box. The 89 is maroon and out of service and the 90 is Blue. The cocker spaniel is about 7-8 years old, he was a stray.
twin_diesels is offline   Reply With Quote
