Re: PCM code's
I don't know if it overrides everything or not. I tried my chip in that 94 pcm. The truck would run very rough and then die. I then pulled the chip and it would run just fine. I'm going to see how much the stealership would charge me to reflash the PCM.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
