Diesel Forum - TheDieselStop.com - View Single Post - DieselKleen question/Thanks for all the reply's...:(
Old 03-06-2005, 05:48 PM   #2 (permalink)
NCHornet
NCHornet's Avatar
Re: DieselKleen question/Thanks for all the reply's...:(
Well if my math is right you should be using 24 oz for your size tank. I also have this tank and that is what I use. This is the strong measurement, they also give one at half this strength. I bought a nice funnel at Walmart that haz the oz markings on the side, it has a long flevible hose on it with a shut off valve, you simply twist it and it is closed, fill the top to 24 oz stick the hose in the tank and un twist the valve and it dumps it in the tank. You can add it now after a few miles it will mix itself in just fine. I hope this helps.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline   Reply With Quote
