Diesel Forum - TheDieselStop.com - View Single Post - DANA AXLE IDENTIFICATION
Old 09-06-1999, 07:57 PM   #1 (permalink)
89 Camper
I need help in identifying my axle housing and its capacity. I am new to your web site in asking questions but not in surfing it. I am posting this on a couple of web sites.
Hope this is one of the right web sites for my questions.
I have a diesel E350 van, 1989, long body, 15 passenger, heavy duty with towing package. It has single rear wheels (SRW) but a dual rear wheel (DRW) axle. Axle has 4.10 ratio. Am getting conflicting information on the rear axle capacity but not on the axle being a Dana or DRW axle. I am trying to find the axle capacity. Not the tires or the springs, but the axle. After the axle capacity, I would like to know the wheel bearing capacity. I do not want to endanger 15 people, including myself, by being over loaded.
The dealer I brought the van from said I had a Dana 60 light weight. The manual shows that my axle is "Code 32" and is rated at 6340 pounds. I have read that a Dana 60 is
rated at 5500 pounds. When I originally purchased the van in 89, I was told that the rear needed "E" rated tires and to keep 80 psi in them or they would be overloaded. As I see it, the Dana 60 axle, if rated at 5500 pounds, would be overloaded when I have 15 people in the van. I think this would pose a safety hazard so I am trying to find the axle
identification and capacity as well as the wheel bearing capacity.
Next contradiction. I needed a new grease seal but the originally ordered seal would not fit. It was to small. It took the larger seal. The dealer (not the selling dealer but the dealer where I have repairs done), said I had the heavy duty axle, probably a Dana 70. He said he did not
believe a Dana 60 would stand the weight and the torque from the diesel with a good safety margin.
I measured the axle tube housing and it is just over three and one half inches diameter. A Dana 60 is just over three inches where the Dana 70 is just over three and one half
inches. Then, I looked in the Shop Manual.
Third conflict. The illustrations in the Shop Manual shows I have the Dana 80 housing with the Dana 70 axle brake plate. My axle housing has two metal "fins" stinking up
on the top of it. The axle end has the circle with the top cut off.
At this point, the dealer is not sure what I have.
I have tried the Dana heavy axle fax back web site, www.dana.com/heavyaxle/faxback.html. It has the manual for the Dana 80. Figure 1 is almost exactly like the back of my axle. The circle on each end is the same but there is no bar from the circle to the end of the housing (where the axle tube connects). Figure 2 shows the two "fins" on the Dana 80. I have also been to the web site www.fourwheeler.com/facts/axlegde.html and the picture of the Dana 60 and Dana 70 does not look like my axle housing. However, the right side of the Dana 60 does look like both
sides of my axle housing, the circle without the bar extending to the axle tube. I also called Dana about two months ago but have had no response as of yet.
Now I have checked the axle tag on the Dana web site. The Ford tag is "E9UA HA" with the Dana part number "605413-2". The Dana axle stamp is "605413-21", not "-2" but "-21".
Dana shows "605413-2" to be a Dana 60 axle and based upon the axle brake plate, it is a semi floating design. But both dealers and the Shop Manual agree it is a full floating DRW axle. Another conflict????
On the differential housing flange, top front, both right and left sides, the axle has "80 ISU" stamped in raised letters. On the back bottom left flange, the axle has
"42853" stamped in raised numbers. By the way, a Felpro 72059 (or RDS 6095-1) gasket for a Dana 60 or Dana 70 will fit the housing cover.
This is a long email but am trying to convey as much info as possible to assist if anyone can help. Smile, things keep getting better.
To recap. I have an 89 E350, diesel, 15 passenger, heavy duty, towing package, 4.10 rear, SRW with a DRW axle. The axle tubes are just over three and one half inches in
diameter. Axle is a Dana DRW axle.
HELP!!! What is the axle and the axle capacity? Also, does anyone know the wheel bearing capacity?
Ready to appreciate the information,
Ron
89 Camper
89 E350, 7.3, used as 15 passenger van pool until insurance reached the clouds, now the long body is a live in camper. Camper has only internal mods. Why? Insurance. But have lived in for four weeks at a time so it must be OK.
All OEM except for air conditioner. Oh, some maintenance items have been replaced.
89 Camper is offline   Reply With Quote
