Diesel Forum - TheDieselStop.com - View Single Post - Tranny cooler question
Old 03-08-2005, 12:01 AM   #6 (permalink)
fordmastertech
fordmastertech's Avatar
Re: Tranny cooler question
The 4R100 transmission has a external fluid bypass for cold operation on the side of the transmission where the cooler lines attach. When the transmission is cold no fluid goes through the cooler lines or coolers ,it's bypassed. When you remove the line and run it cold it will shoot out of the rear port and by the time you notice it you will have many quarts of fluid on the ground and none in your recovery bucket. It can happen in any climate areas. Hope this makes sense.
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline   Reply With Quote
