Re: Water Pump..What years interchange
I am not sure about a SD fitting a 97. I do know a 96-97 will work on a 95. So I imagine a 95 would work on a 97 also. There are a few differences, but they are minor. One is the heater hose fitting is difference. The 96-97 takes an O-ring where as the 95 is screw in. And the bottom of the pump is two pieces on the 96-97 where as the 95 is one piece. Maybe someone else can help you with the SD question.
[img]/ubbthreads/images/graemlins/phoney.gif[/img]
02 F250, 4X4, 4R100, 3.73, Amsoil Air Filter, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug and Intercooler boots, 6.0 Transmission Cooler.
