Diesel Forum - TheDieselStop.com - View Single Post - Water Pump..What years interchange
Old 04-21-2005, 11:16 PM   #3 (permalink)
JOAT
Re: Water Pump..What years interchange
94-97 will interchange. The most important difference is the thermostat. A 96-97 thermostat will not fit in a 94-95, as it is about 3/4" longer. If you put a 94-95 thermostat in a 96-97 pump, it will fit, but will not block the bypass port. This can lead to overheating in parts of the engine even while the gauge reads normal!
If in doubt which pump you have, measure from where the thermostat seats to down inside where the bypass port is (Webshots PIC) . Approx 1.5" on 94-95, 2.3 inch on 96-97.
While expensive, you can also upgrade to the International Pump with an integral coolant filter. There are some threads with good descriptions of this, but until I can search the archives I can't get them for you. Maybe someone has a write-up [img]/ubbthreads/images/graemlins/shrug.gif[/img]
JOAT is offline   Reply With Quote
