Re: Water Pump..What years interchange
While expensive, you can also upgrade to the International Pump with an integral coolant filter. There are some threads with good descriptions of this, but until I can search the archives I can't get them for you. Maybe someone has a write-up [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Anyone have a write-up on the IH pump swap? My pump started leaking today and I need to replace it. Hard to find much information with the archive search down..
Powerstrokeshop.com lists the 95-96 pump and list a different one for 97 and it is a little cheaper. I have the longer stat in my 1996 so I suppose if I go with a Ford pump I should order the 97' pump to get the right one?
1996 F-350, 4X4, XLT, C/C, 5sp, 4.10, Chip, DPPI Down Pipe, Tymar intake, Shackle reversal, 315 Toyo MT's, 67,000 miles.
