Re: Water Pump..What years interchange
OK guys i have a oem style waterpump from IH that has the one piece bottom hose connecter, is this a 95 style pump? I put a 97 thermostat in the pump , do i have the wrong one in there? The 94-95 pump is the only one that has the one piece bottom hose connecter? I do seem to remember the pump from IH looked a little different than the one i took off.In the summer when pulling hard the temp gauge will head to the hot side a ways also.
Stevo
97 thermostat would not fit a 95 pump (too long), so you're OK. Some aftermarket newer pumps have the cast inlet.
