Diesel Forum - TheDieselStop.com - View Single Post - Overdrive Off vs. Tow/Haul
Old 05-03-2005, 07:56 AM   #3 (permalink)
Casey_1
Re: Overdrive Off vs. Tow/Haul
Never have seen a Torqueshift with a O/D button on the stalk, only tow/haul.
TorqShift transmissions in the 6.0L diesel vans have OD off, not tow/haul. I have no idea why, but that's the way it is.
OD off prevents the transmission from shifting to the highest gear, which is overdrive.
Tow/Haul changes the shift schedule so that it shifts to a higher gear at a higher RPM than in the normal mode. This helps move the heavier load. Also, the Tow/Haul will automatically downshift to help with engine braking. Tow/Haul will allow the transmission to shift to all gears including overdrive.
Casey_1 is offline   Reply With Quote
